メインコンテンツにスキップ
Samsung SGH-X495 Speakers Replacement
必要な工具と部品
  1. Samsung SGH-X495 Speakers Replacement, Face Plate: 手順 1、 1の画像 1
    • First, remove the 2 silver stickers (as indicated by the circles) with a a safety or push pin to reveal 2 screws.
  2. Samsung SGH-X495 Speakers Replacement: 手順 2、 1の画像 1
    • Remove the 2 (5.6 mm) philips head screws with your safety or push pin.
  3. Samsung SGH-X495 Speakers Replacement: 手順 3、 2の画像 1 Samsung SGH-X495 Speakers Replacement: 手順 3、 2の画像 2
    • As shown above, with a plastic pry tool, begin working at the top corner and down each side. The face plate has 10 tabs that hook into the phone's body.
    • Before removing the 2 tabs on the bottom, the 3 tabs on either side must be free first.
    • Note: The bottom 2 are the most challenging to remove.
    • Note: When reassembling start with the bottom two tabs.
  4. Samsung SGH-X495 Speakers Replacement: 手順 4、 2の画像 1 Samsung SGH-X495 Speakers Replacement: 手順 4、 2の画像 2
    • Continue down each side toward the bottom with your pry tool.
    • Note: It may help to use multiple pry tools to help hold it open.
    • Second photo: location of the tabs.
  5. Samsung SGH-X495 Speakers Replacement: 手順 5、 2の画像 1 Samsung SGH-X495 Speakers Replacement: 手順 5、 2の画像 2
    • With 8 tabs released, the face plate is nearly free.
    • With the phone in your left hand, gently wiggle the face plate from side to side and push the face place upward.
    • Note: A strip of double sided tape holds the faceplate, so expect some resistance
  6. Samsung SGH-X495 Speakers Replacement, Speakers: 手順 6、 2の画像 1 Samsung SGH-X495 Speakers Replacement, Speakers: 手順 6、 2の画像 2
    • Remove the 2 speakers by gently prying them up.
    • The speakers are attached with double sided tape.
  7. Samsung SGH-X495 Speakers Replacement: 手順 7、 1の画像 1
    • With the speakers free from the phones body the screen is loose as well.
    • The desired solder joint can be accessed to attach a new speaker.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Matthew Hove
メンバー登録日: 01/05/11
1,031 ポイント
10のガイドは作成済み
チーム
Cal Poly, Team 3-40, Regan Winter 2011 Cal Poly, Team 3-40, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S3G40
4 メンバー
20のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 1,754
