メインコンテンツにスキップ
Samsung SGH-X495 Charger Jack Replacement
必要な工具と部品
  1. Samsung SGH-X495 Charger Jack Replacement, Battery: 手順 1、 2の画像 1 Samsung SGH-X495 Charger Jack Replacement, Battery: 手順 1、 2の画像 2
    • Use thumb nail to release the white hook; then use fingertip to pry the battery loose starting from the top.
    • Second photo gives a view from the back of the phone and battery.
  2. Samsung SGH-X495 Charger Jack Replacement, Backplate: 手順 2、 1の画像 1
    • Remove the 4 (4.7mm) philips head screws.
  3. Samsung SGH-X495 Charger Jack Replacement: 手順 3、 1の画像 1
    • Unplug the rubber charger outlet cover.
  4. Samsung SGH-X495 Charger Jack Replacement: 手順 4、 1の画像 1
    • Unplug the rubber headset jack cover.
  5. Samsung SGH-X495 Charger Jack Replacement: 手順 5、 2の画像 1 Samsung SGH-X495 Charger Jack Replacement: 手順 5、 2の画像 2
    • Begin by inserting the pry tool near the charger jack.
    • There are 4 tabs to release.
    • Start at the bottom and slide the tool up, lifting the silver front of the phone away from the white backing.
    • Loosen the 2 side tabs before moving on to the top two.
    • See the second photo to see location of the tabs.
    • Be careful of the ribbon wires shown in second photo.
  6. Samsung SGH-X495 Charger Jack Replacement: 手順 6、 2の画像 1 Samsung SGH-X495 Charger Jack Replacement: 手順 6、 2の画像 2
    • Once the two side tabs are free; gently pry the white backing down to release the top two tabs.
    • Hold the phone with the left hand as shown
    • Wiggle the white backplate from side to side while pulling down with the right hand.
  7. Samsung SGH-X495 Charger Jack Replacement, Motherboard: 手順 7、 1の画像 1
    • Remove the ribbon wires connecting to the screen using the pry tool.
  8. Samsung SGH-X495 Charger Jack Replacement: 手順 8、 1の画像 1
    • 2 tabs hold the motherboard in place.
    • Release the labeled tabs with the pry tool from the location shown.
  9. Samsung SGH-X495 Charger Jack Replacement: 手順 9、 1の画像 1
    • Separate the motherboard from the phone.
  10. Samsung SGH-X495 Charger Jack Replacement, Charger Jack: 手順 10、 1の画像 1
    • Solder connections are accessable to replace the Chargers Jack.
終わりに
作成者
4人の作成者と共同で作成されました。
Matthew Hove
メンバー登録日: 01/05/11
1,031 ポイント
10のガイドは作成済み
チーム
Cal Poly, Team 3-40, Regan Winter 2011 Cal Poly, Team 3-40, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S3G40
4 メンバー
20のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 1,675
