パーツ
パーツは指定されていません。
  1. Use thumb nail to release the white hook; then use fingertip to pry the battery loose starting from the top. Second photo gives a view from the back of the phone and battery.
    • Use thumb nail to release the white hook; then use fingertip to pry the battery loose starting from the top.
    • Second photo gives a view from the back of the phone and battery.
  2. Remove the 4 (4.7mm) philips head screws.
    • Remove the 4 (4.7mm) philips head screws.
  3. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  4. Unplug the rubber charger outlet cover.
    • Unplug the rubber charger outlet cover.
  5. Unplug the rubber headset jack cover.
    • Unplug the rubber headset jack cover.
  6. Begin by inserting the pry tool near the charger jack. There are 4 tabs to release.
    • Begin by inserting the pry tool near the charger jack.
    • There are 4 tabs to release.
    • Start at the bottom and slide the tool up, lifting the silver front of the phone away from the white backing.
    • Loosen the 2 side tabs before moving on to the top two.
    • See the second photo to see location of the tabs.
    • Be careful of the ribbon wires shown in second photo.
  7. Once the two side tabs are free; gently pry the white backing down to release the top two tabs. Hold the phone with the left hand as shown
    • Once the two side tabs are free; gently pry the white backing down to release the top two tabs.
    • Hold the phone with the left hand as shown
    • Wiggle the white backplate from side to side while pulling down with the right hand.
まとめ
Matthew Hove
メンバー登録日: 2011年01月05日
1,031 ポイント
10のガイドは作成済み
チーム
Cal Poly, Team 3-40, Regan Winter 2011 Cal Poly, Team 3-40, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S3G40
4 メンバー
20のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,191
