はじめに
Replace a broken loud speaker.
必要な工具と部品
Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
Locate the two wires (black and red) which connect the speaker to the logic board.
Using your nails, tweezers, or any precise grabbing tool, pinch the speaker connector (clear plastic plug that goes into the logic board) and pull gently. It should pop out easily.
Once the wires are disconnected and the screws removed, the white plastic cover can easily be removed from the logic board.
Use any small flat object to remove the speaker from the white plastic cover by wedging your tool between the speaker and the cover.
