メインコンテンツにスキップ
Samsung SGH-X105 Earpiece Speaker Replacement
必要な工具と部品
  1. Samsung SGH-X105 Earpiece Speaker Replacement, Battery: 手順 1、 1の画像 1
    • Rotate the phone onto its front side so that the LCD screen is facing away from you.
  2. Samsung SGH-X105 Earpiece Speaker Replacement: 手順 2、 3の画像 1 Samsung SGH-X105 Earpiece Speaker Replacement: 手順 2、 3の画像 2 Samsung SGH-X105 Earpiece Speaker Replacement: 手順 2、 3の画像 3
    • Remove the battery by pressing down on the battery release button while sliding the battery downwards.
  3. Samsung SGH-X105 Earpiece Speaker Replacement, Front & Back Panels: 手順 3、 1の画像 1
    • Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
    • Complete removal of screws may not be necessary.
  4. Samsung SGH-X105 Earpiece Speaker Replacement: 手順 4、 3の画像 1 Samsung SGH-X105 Earpiece Speaker Replacement: 手順 4、 3の画像 2 Samsung SGH-X105 Earpiece Speaker Replacement: 手順 4、 3の画像 3
    • Carefully separate the front and back panels by gently prying them apart. Start at the bottom of the phone (near the AC charger input).
    • Volume control button will be unsecured and may fall out as soon as the panels are separated.
    • Gentle force may be required to separate the panels at the top latch.
    • There are two wires connecting the front and back panels. Be careful not to rip these wires out when separating the panels.
  5. Samsung SGH-X105 Earpiece Speaker Replacement: 手順 5、 2の画像 1 Samsung SGH-X105 Earpiece Speaker Replacement: 手順 5、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
  6. Samsung SGH-X105 Earpiece Speaker Replacement, Earpiece Speaker: 手順 6、 1の画像 1
    • Put aside the back panel. You will only be working with the front panel from here on.
  7. Samsung SGH-X105 Earpiece Speaker Replacement: 手順 7、 3の画像 1 Samsung SGH-X105 Earpiece Speaker Replacement: 手順 7、 3の画像 2 Samsung SGH-X105 Earpiece Speaker Replacement: 手順 7、 3の画像 3
    • Using a SL 1.5 flathead screwdriver (or any small prying tool), pry the speaker from the plastic front cover.
    • The earpiece speaker is magnetic so you can use a magnet to remove the earpiece speaker from the plastic front cover once loosened.
    • You can apply your own adhesive to secure your replaced speaker if desired during reassembly.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Chris Lao
メンバー登録日: 04/15/10
16 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 28-29, Regan Spring 2010 Cal Poly, Team 28-29, Regan Spring 2010人のメンバー
CPSU-REGAN-S10S28G29
4 メンバー
12のガイドは作成済み
コメント 1 件
Where can I get a replacement speaker?
NickyPhils - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 1,953
