はじめに
With this guide you can clean or repair a faulty keypad.
  1. Place phone face down so battery cover is showing.
    • Place phone face down so battery cover is showing.
  2. Use thumb to push the cover down and off.
    • Use thumb to push the cover down and off.
    • Lift battery cover off the device.
    • Remove the five screws with a size 00 screwdriver. There are 4 in the corners and one on the top as shown.
    • Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
    • Some force must be applied, and the back cover should come off.
    • Detach the tab from the logic board shown by using the Ipod Opening Tool
    • Use the Ipod Opening Tool to lift the green logic board carefully.
    • Remove the logic board from the device.
    • The keypad should peel off the logic board with a gentle pull.
    • Use a clean, soft, cotton cloth to gently remove any debris or liquid that may be located on the pad or logic board interface.
まとめ
Shawn
メンバー登録日: 2010年04月14日
1 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 29-81, Johann Spring 2010 Cal Poly, Team 29-81, Johann Spring 2010人のメンバー
CPSU-JOHANN-S10S29G81
4 メンバー
8のガイドは作成済み
コメント1件
This was very helpful. There is no other place I could find a guide to take this phone apart. Even Samsung chat was unable to help!! Thanks very much!
Steve - 返信
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,256
