メインコンテンツにスキップ
Samsung SGH-A237 Camera Replacement
必要な工具と部品
  1. Samsung SGH-A237 Camera Replacement, Camera: 手順 1、 1の画像 1
    • Place the phone on a flat surface with the camera facing upwards.
    • Have a designated space to keep track of each small part.
  2. Samsung SGH-A237 Camera Replacement: 手順 2、 1の画像 1
    • Open the phone.
    • Remove the two rubber soft screw covers below the viewing screen using a pair of tweezers.
  3. Samsung SGH-A237 Camera Replacement: 手順 3、 1の画像 1
    • Loosen the screws under the soft screw covers using a Phillips #00 screwdriver.
  4. Samsung SGH-A237 Camera Replacement: 手順 4、 3の画像 1 Samsung SGH-A237 Camera Replacement: 手順 4、 3の画像 2 Samsung SGH-A237 Camera Replacement: 手順 4、 3の画像 3
    • Failure to utilize the specified tool may cause damage to the device.
    • Locate the black cover plate on the back side of the viewing screen. It will show the AT&T and Samsung logos.
    • Look on the right side of the phone for the crease in between the black back cover and the front silver cover of the viewing screen.
    • Pry the cover plate off using a plastic opening tool.
  5. Samsung SGH-A237 Camera Replacement: 手順 5、 2の画像 1 Samsung SGH-A237 Camera Replacement: 手順 5、 2の画像 2
    • Identify the metal bracket that covers the internal body.
    • Identify the metal tabs surrounding the metal bracket mentioned in the previous step.
    • Remove the metal bracket using a small pick or a Phillips #00 screwdriver.
    • Close the phone.
  6. Samsung SGH-A237 Camera Replacement: 手順 6、 1の画像 1
    • Find the camera on the upper part of the phone. It will be displayed as a small black circle.
    • Follow the copper ribbon connected to the camera downward to the black connection port.
  7. Samsung SGH-A237 Camera Replacement: 手順 7、 2の画像 1 Samsung SGH-A237 Camera Replacement: 手順 7、 2の画像 2
    • Failure to utilize the specified tool in the proper way may cause damage to the device.
    • Pry up the black connector using a pick. This should lock the black connector into an upward position, which will release the copper ribbon connected to the phone's camera.
  8. Samsung SGH-A237 Camera Replacement: 手順 8、 2の画像 1 Samsung SGH-A237 Camera Replacement: 手順 8、 2の画像 2
    • Gently grasp the copper ribbon attached to the camera using a pair of tweezers.
    • Gently pull copper ribbon towards the camera. This should pull the copper ribbon out completely.
  9. Samsung SGH-A237 Camera Replacement: 手順 9、 1の画像 1
    • Remove the camera.
終わりに
作成者
13人の作成者と共同で作成されました。
Jonathon
メンバー登録日: 10/15/14
10 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-4, Mccook Fall 2014 Ohio State, Team 1-4, Mccook Fall 2014人のメンバー
OSU-MCCOOK-F14S1G4
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 335
