メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのSamsung SGH-A117を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Samsung SGH-A117: Breakdown and Reassembly, Samsumg SGH-A117: 手順 1、 1の画像 1
    • This is the Samsung SGH-A117.
  2. Samsung SGH-A117: Breakdown and Reassembly, Backside of the cellphone: 手順 2、 1の画像 1
    • This is the back view following the removal of the back cover and battery.
  3. Samsung SGH-A117: Breakdown and Reassembly, Removing Screws: 手順 3、 1の画像 1
    • Use a screwdriver to remove screws around the frame.
    • Use a PH00 size screw to operate this step.
    • The screws are extremely small. It is recommended to have a small container to keep track of the screws.
  4. Samsung SGH-A117: Breakdown and Reassembly, Removing the Back Cover: 手順 4、 2の画像 1 Samsung SGH-A117: Breakdown and Reassembly, Removing the Back Cover: 手順 4、 2の画像 2
    • Insert the spudger under the back cover at the marked locations and gently lift to remove the back cover.
    • The end of the phone closest to the hinge will require additional force to lift.
    • Be careful not to bend the cover during the removal process.
  5. Samsung SGH-A117: Breakdown and Reassembly, Separate Circuit Connector from Logic Board: 手順 5、 1の画像 1
    • Use a spudger to gently lift the circuit connector from the logic board.
    • Be careful not to remove the circuit connector from the phone.
  6. Samsung SGH-A117: Breakdown and Reassembly, Lift Logic Board: 手順 6、 2の画像 1 Samsung SGH-A117: Breakdown and Reassembly, Lift Logic Board: 手順 6、 2の画像 2
    • Use a spudger to lift the logic board and separate it from the main body of the phone.
    • It is recommended to lift from the bottom part of the logic board as shown in the picture.
    • Be careful not to lose the volume button, which is loosely attached to the logic board.
  7. Samsung SGH-A117: Breakdown and Reassembly, Remove Keypad: 手順 7、 2の画像 1 Samsung SGH-A117: Breakdown and Reassembly, Remove Keypad: 手順 7、 2の画像 2
    • Gently push the keyboard from the case as shown in the picture.
  8. Samsung SGH-A117: Breakdown and Reassembly, Layout of Disassembled Device: 手順 8、 1の画像 1
    • 1 Case
    • 1 Keyboard
    • 1 Logic Board
    • 1 Volume Control
    • 1 Back Cover
    • 5 Screws
作成者
6人の作成者と共同で作成されました。
Justin
メンバー登録日: 10/06/14
150 ポイント
2のガイドは作成済み
チーム
Aristotle Aristotle人のメンバー
Community
5 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 827
