はじめに
Use this guide to replace your Samsung SGH A707 phone's display.
必要な工具と部品
Unscrew the six screws on the back of the phone using the Phillips #0 screw driver.
Use the Phillips #0 screw driver to remove the two screws.
Place the screws in a safe place.
Use the prying tool to gently pry the screen off, by slowly moving the prying tool around the entire edge of the screen (roughly highlighted with a red rectangle). You must be very gentle, otherwise the screen will crack.
Separate the two flaps to make handling easier.
Use a screw driver to press a latch in along the axis of the hinge and simultaneously pull the pieces apart.
Gently pull the flat cable through the hinge.
