はじめに
This guide will cover the removal of the Samsung SCH-U340 top casing.
必要な工具と部品
Turn the cell phone so that the back side is facing you.
Press the upper indent and slide the back cover down.
The outer casing consists of two separate parts on the upper and lower halves of the device. The upper outer casing is held on through a combination of screws and tabs.
First, remove the plastic plugs covering the screws with a spudger.
ある他の人がこのガイドを完成しました。
