はじめに
A step by step guide to removing and replacing the Samsung SCH U340's internal antennae.
パーツ
パーツは必要ありません。
  1. Turn the cell phone so that the back side is facing you. Press the upper indent and slide the back cover down.
    • Turn the cell phone so that the back side is facing you. Press the upper indent and slide the back cover down.
  2. Pull battery up from indent at the bottom and slide it out.
    • Pull battery up from indent at the bottom and slide it out.
  3. Set the battery aside.
    • Set the battery aside.
  4. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
    • The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
  6. Use a spudger to pry the back assembly off of the device. Use a spudger to pry the back assembly off of the device.
    • Use a spudger to pry the back assembly off of the device.
  7. On the bottom casing, there should be a single metal screw holding the antennae in. Remove this screw.
    • On the bottom casing, there should be a single metal screw holding the antennae in. Remove this screw.
  8. Pry the antennae off by inserting a flat object such as a spudgel into the slot marked in yellow and pushing upwards. Pry the antennae off by inserting a flat object such as a spudgel into the slot marked in yellow and pushing upwards.
    • Pry the antennae off by inserting a flat object such as a spudgel into the slot marked in yellow and pushing upwards.
まとめ
David Gomez
メンバー登録日: 2010年01月21日
1 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 3-21, Maness Winter 2010 Cal Poly, Team 3-21, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S3G21
4 メンバー
10のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,094
