はじめに
This guide will teach you how to remove your Samsung SCH-A950's speakers.
必要な工具と部品
Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
Use tweezers to peel back the sticker on the backside of the speaker to reveal a screw that holds the speaker in place.
Using a phillips #00 screwdriver, remove the screw holding the speaker. On each side.
ある他の人がこのガイドを完成しました。
