メインコンテンツにスキップ
Samsung SCH-A670 Screen Replacement
必要な工具と部品
  1. Samsung SCH-A670 Screen Replacement, Battery Cover: 手順 1、 1の画像 1
    • Slide the latch on the back of the phone up.
  2. Samsung SCH-A670 Screen Replacement, Battery: 手順 2、 1の画像 1
    • Remove the battery.
  3. Samsung SCH-A670 Screen Replacement, Logic Board: 手順 3、 1の画像 1
    • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
  4. Samsung SCH-A670 Screen Replacement: 手順 4、 1の画像 1
    • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
  5. Samsung SCH-A670 Screen Replacement: 手順 5、 1の画像 1
    • With a #0 Phillips screwdriver remove the screw which you just uncovered.
  6. Samsung SCH-A670 Screen Replacement: 手順 6、 2の画像 1 Samsung SCH-A670 Screen Replacement: 手順 6、 2の画像 2
    • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
    • Then disconnect the small power connector near the top of the phone.
  7. Samsung SCH-A670 Screen Replacement: 手順 7、 1の画像 1
    • Gently pry up the ribbon-type connector with the spudger.
  8. Samsung SCH-A670 Screen Replacement: 手順 8、 1の画像 1
    • Carefully pry the logic board from the case with the spudger.
  9. Samsung SCH-A670 Screen Replacement, Keypad: 手順 9、 1の画像 1
    • Once the logic board has been removed, peel the keypad up.
  10. Samsung SCH-A670 Screen Replacement, Keypad Housing: 手順 10、 2の画像 1 Samsung SCH-A670 Screen Replacement, Keypad Housing: 手順 10、 2の画像 2
    • When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing.
  11. Samsung SCH-A670 Screen Replacement, Screen Casing: 手順 11、 1の画像 1
    • Remove screws with #0 Phillips screwdriver.
  12. Samsung SCH-A670 Screen Replacement: 手順 12、 1の画像 1
    • Carefully pry apart the casing with the spudger tool.
  13. Samsung SCH-A670 Screen Replacement, Screen: 手順 13、 1の画像 1
    • Use the spudger to carefully pry off the speaker.
  14. Samsung SCH-A670 Screen Replacement: 手順 14、 1の画像 1
    • Carefully pry off the ringer with the spudger.
  15. Samsung SCH-A670 Screen Replacement: 手順 15、 1の画像 1
    • Carefully pry off the screen with the spudger.
終わりに
作成者
5人の作成者と共同で作成されました。
Nathan Brink
メンバー登録日: 04/11/10
19 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 34-59, Forte Spring 2010 Cal Poly, Team 34-59, Forte Spring 2010人のメンバー
CPSU-FORTE-S10S34G59
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 3,434
