はじめに
The screen casing may become worn or broken over time. This guide will allow you to remove/replace it.
パーツ
パーツは必要ありません。
  1. Slide the latch on the back of the phone up.
    • Slide the latch on the back of the phone up.
  2. Remove the battery.
    • Remove the battery.
  3. After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
    • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
  4. Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
    • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
  5. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  6. With a #0 Phillips screwdriver remove the screw which you just uncovered.
    • With a #0 Phillips screwdriver remove the screw which you just uncovered.
  7. Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open. Then disconnect the small power connector near the top of the phone.
    • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
    • Then disconnect the small power connector near the top of the phone.
  8. Gently pry up the ribbon-type connector with the spudger.
    • Gently pry up the ribbon-type connector with the spudger.
  9. Carefully pry the logic board from the case with the spudger.
    • Carefully pry the logic board from the case with the spudger.
  10. Once the logic board has been removed, peel the keypad up.
    • Once the logic board has been removed, peel the keypad up.
  11. When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing. When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing.
    • When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing.
  12. Remove screws with #0 Phillips screwdriver.
    • Remove screws with #0 Phillips screwdriver.
  13. Carefully pry apart the casing with the spudger tool.
    • Carefully pry apart the casing with the spudger tool.
まとめ
Nathan Brink
メンバー登録日: 2010年04月11日
1 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 34-59, Forte Spring 2010 Cal Poly, Team 34-59, Forte Spring 2010人のメンバー
CPSU-FORTE-S10S34G59
4 メンバー
14のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,819
