この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
You will take the camera apart in order to replace the damaged LCD screen and restore functionality.
必要な工具と部品
Remove all screws along the edges of the camera, using a #00 Phillips screwdriver.
Carefully pull the back case (the side showing the LCD screen) away from the front half.
There are clips securing the top of the back case. Do not be afraid to use the proper amount of force to remove the back case.
Turn the camera around to the front (the lens side). Carefully remove the front case.
There are also clips on the lens' side as well, so do not be afraid to use force.
3 の人々がこのガイドを完成させました。
