はじめに
In order to access the keypad, you must first remove the back cover, battery and rear case from the cell phone.
必要な工具と部品
Turn the phone over in the palm of your hand, with the screen facing down.
While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
You should now be able to lift the plate completely off of the phone.
Using a pair of tweezers, grip the keypad gently.
Lift the keypad out of the phone and replace it (if necessary).
