はじめに
In this guide, we will be replacing the USB module of the speaker, which also houses the button used in pairing the speaker for Wi-Fi capabilities. You will need to remove the bottom cover, unplug the connector from the motherboard to it, and remove it from the speaker assembly.
必要な工具と部品
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
