はじめに
This guide will walk you through the process of removing the bottom of the speaker, the outer shell, the subwoofer and accessing the tweeter speaker for removal.
必要な工具と部品
Remove the two 12mm long screws with the Phillips #1 screwdriver.
Unplug white plug connected to the green circuit board.
Remove the six 8mm screws using the Phillips #1 screwdriver.
Remove the six 12mm screws using the Phillips #1 screwdriver.
ある他の人がこのガイドを完成しました。
