メインコンテンツにスキップ
Samsung Radiant360 R3 Motherboard Replacement
必要な工具と部品
  1. Samsung Radiant360 R3 Motherboard Replacement, Wireless Setup Button and USB Module: 手順 1、 3の画像 1 Samsung Radiant360 R3 Motherboard Replacement, Wireless Setup Button and USB Module: 手順 1、 3の画像 2 Samsung Radiant360 R3 Motherboard Replacement, Wireless Setup Button and USB Module: 手順 1、 3の画像 3
    この手順で使用する道具:
    • Flip the device so that the bottom of the device is facing you. Remove these feet with a pair of tweezers.
    • Remove the four 10mm long screws with the Phillips #1 screwdriver.
  2. Samsung Radiant360 R3 Motherboard Replacement: 手順 2、 1の画像 1
    • Remove the bottom shell from the speaker.
  3. Samsung Radiant360 R3 Motherboard Replacement: 手順 3、 2の画像 1 Samsung Radiant360 R3 Motherboard Replacement: 手順 3、 2の画像 2
    • Remove the connector from the board by pressing down on the center tab while nudging the connector away with a spudger.
    • Be careful not to pull directly on the wires or apply too much pressure, or you risk breaking the connector.
  4. Samsung Radiant360 R3 Motherboard Replacement: 手順 4、 1の画像 1
    • Remove the two 10mm long screws from the board utilizing the Phillips #1 screwdriver.
  5. Samsung Radiant360 R3 Motherboard Replacement: 手順 5、 1の画像 1
    • Use a spudger to press the plastic tab away from the board until the board pops up.
    • Remove the board with the USB module from the device.
  6. Samsung Radiant360 R3 Motherboard Replacement, Wireless Module: 手順 6、 2の画像 1 Samsung Radiant360 R3 Motherboard Replacement, Wireless Module: 手順 6、 2の画像 2
    • Remove the two 12mm long screws with the Phillips #1 screwdriver.
    • Unplug white plug connected to the green circuit board.
  7. Samsung Radiant360 R3 Motherboard Replacement: 手順 7、 2の画像 1 Samsung Radiant360 R3 Motherboard Replacement: 手順 7、 2の画像 2
    • Remove the four 12mm long screws with the Phillips #1 screwdriver.
    • Remove the cover, and slide the cord through the hole.
  8. Samsung Radiant360 R3 Motherboard Replacement: 手順 8、 3の画像 1 Samsung Radiant360 R3 Motherboard Replacement: 手順 8、 3の画像 2 Samsung Radiant360 R3 Motherboard Replacement: 手順 8、 3の画像 3
    この手順で使用する道具:
    • Remove rubber covers covering the screws with pair of tweezers.
    • Remove the six 12mm screws that are under the rubber covers with the Phillips #1 screwdriver.
  9. Samsung Radiant360 R3 Motherboard Replacement: 手順 9、 1の画像 1
    • Remove the unscrewed cover as much as possible.
    • It is very difficult to get plugs at the end of the cord through the cover without breaking, so just slide to the edge.
  10. Samsung Radiant360 R3 Motherboard Replacement: 手順 10、 3の画像 1 Samsung Radiant360 R3 Motherboard Replacement: 手順 10、 3の画像 2 Samsung Radiant360 R3 Motherboard Replacement: 手順 10、 3の画像 3
    • Push the body out through the outer shell of device.
    • Carefully push the ring attached to the cable through the shell.
  11. Samsung Radiant360 R3 Motherboard Replacement: 手順 11、 3の画像 1 Samsung Radiant360 R3 Motherboard Replacement: 手順 11、 3の画像 2 Samsung Radiant360 R3 Motherboard Replacement: 手順 11、 3の画像 3
    • Remove the eight 12mm long screws around the body with the Phillips #1 screwdriver.
  12. Samsung Radiant360 R3 Motherboard Replacement: 手順 12、 2の画像 1 Samsung Radiant360 R3 Motherboard Replacement: 手順 12、 2の画像 2
    • Pry the two halves of the body open using a metal spudger.
  13. Samsung Radiant360 R3 Motherboard Replacement: 手順 13、 3の画像 1 Samsung Radiant360 R3 Motherboard Replacement: 手順 13、 3の画像 2 Samsung Radiant360 R3 Motherboard Replacement: 手順 13、 3の画像 3
    • Remove the plugs located topmost right and closest to the bottom in picture.
  14. Samsung Radiant360 R3 Motherboard Replacement: 手順 14、 1の画像 1
    • Remove the four 12mm long screws with the Phillips #1 screwdriver .
  15. Samsung Radiant360 R3 Motherboard Replacement: 手順 15、 1の画像 1
    • Unscrew the four 8mm screws on the side of the motherboard with the Phillips #1 screwdriver .
    • Remove the Wireless Module from the device.
  16. Samsung Radiant360 R3 Motherboard Replacement, Subwoofer: 手順 16、 2の画像 1 Samsung Radiant360 R3 Motherboard Replacement, Subwoofer: 手順 16、 2の画像 2
    • Disconnect the plug in the device.
  17. Samsung Radiant360 R3 Motherboard Replacement: 手順 17、 1の画像 1
    • Slide the subwoofer out of the speaker.
  18. Samsung Radiant360 R3 Motherboard Replacement, Motherboard: 手順 18、 2の画像 1 Samsung Radiant360 R3 Motherboard Replacement, Motherboard: 手順 18、 2の画像 2
    • Disconnect the six plugs on the motherboard.
  19. Samsung Radiant360 R3 Motherboard Replacement: 手順 19、 1の画像 1
    • Remove the ZIF cable.
    • Pull up the tab with a spudger, and life the cable.
  20. Samsung Radiant360 R3 Motherboard Replacement: 手順 20、 2の画像 1 Samsung Radiant360 R3 Motherboard Replacement: 手順 20、 2の画像 2
    • Remove the four 12mm screws with the Phillips #1 screwdriver .
    • Remove the motherboard from the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Fadi Alzammar
メンバー登録日: 04/22/18
782 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S25-G18, Maness Spring 2018 Cal Poly, Team S25-G18, Maness Spring 2018人のメンバー
CPSU-MANESS-S18S25G18
4 メンバー
5のガイドは作成済み
1件のガイドコメント
What kind of DAC is in the motherboard?
Gera Mare - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 466
