メインコンテンツにスキップ
Samsung Radiant 360 R1 Bluetooth Module Replacement
必要な工具と部品
  1. Samsung Radiant 360 R1 Bluetooth Module Replacement, Micro USB / Power Port Panel: 手順 1、 1の画像 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Use the plastic opening tool to lift and remove the rubber grommet plugs.
  2. Samsung Radiant 360 R1 Bluetooth Module Replacement: 手順 2、 1の画像 1
    • Using a PH1 Philips screwdriver, remove four (9.5mm x 1.6mm) screws from the base plate.
    • Remove base plate by stabilizing speaker and using plastic prying tool to pry the base plate from the speaker.
  3. Samsung Radiant 360 R1 Bluetooth Module Replacement: 手順 3、 1の画像 1
    • Place the speaker on the table with the Touch Pad facing down. This will leave you with the Port Panel exposed.
    • Remove speaker grill by stabilizing speaker on a table and applying pressure to the bottom of the speaker. Slide the speaker grill up and away from the remaining endcap.
  4. Samsung Radiant 360 R1 Bluetooth Module Replacement: 手順 4、 1の画像 1
    • Remove the two exposed (9.5mm x 1.6mm) PH1 Phillips screws on the Port Panel.
    • Remove the Port Panel from the speaker body, exposing the ribbon cables.
  5. Samsung Radiant 360 R1 Bluetooth Module Replacement: 手順 5、 1の画像 1
    • While stabilizing the Port Panel remove the two ribbon cables one at a time by pressing the locking clip down on the ribbon cable connectors and pulling the connector away from the Port Panel.
  6. Samsung Radiant 360 R1 Bluetooth Module Replacement, 1" Tweeter Speaker: 手順 6、 3の画像 1 Samsung Radiant 360 R1 Bluetooth Module Replacement, 1" Tweeter Speaker: 手順 6、 3の画像 2 Samsung Radiant 360 R1 Bluetooth Module Replacement, 1" Tweeter Speaker: 手順 6、 3の画像 3
    • Remove the four (9.5mm x 1.6mm) PH1 Phillips screws on the port speaker body.
    • Remove the Port Panel exposing the subwoofer.
  7. Samsung Radiant 360 R1 Bluetooth Module Replacement: 手順 7、 3の画像 1 Samsung Radiant 360 R1 Bluetooth Module Replacement: 手順 7、 3の画像 2 Samsung Radiant 360 R1 Bluetooth Module Replacement: 手順 7、 3の画像 3
    • Remove the eight (9.5mm x 1.6mm) PH1 Phillips screws on the right side of the speaker body.
    • Remove the one (9.5mm x 1.6mm) PH1 Phillips screw on the left side of the speaker body.
    • The body sides are denoted with a "R" and an "L" for right and left sides.
  8. Samsung Radiant 360 R1 Bluetooth Module Replacement: 手順 8、 1の画像 1
    • Open up the body to expose the inner panel and motherboard.
  9. Samsung Radiant 360 R1 Bluetooth Module Replacement: 手順 9、 3の画像 1 Samsung Radiant 360 R1 Bluetooth Module Replacement: 手順 9、 3の画像 2 Samsung Radiant 360 R1 Bluetooth Module Replacement: 手順 9、 3の画像 3
    • Remove the ribbon cable from the tweeter which is attached to the main motherboard.
    • Slide the tweeter out of the enclosure.
  10. Samsung Radiant 360 R1 Bluetooth Module Replacement, Bluetooth Module: 手順 10、 1の画像 1
    • Slide rubber grommet out of slot on plastic housing.
    • This may have occurred naturally when separating the two halves.
  11. Samsung Radiant 360 R1 Bluetooth Module Replacement: 手順 11、 3の画像 1 Samsung Radiant 360 R1 Bluetooth Module Replacement: 手順 11、 3の画像 2 Samsung Radiant 360 R1 Bluetooth Module Replacement: 手順 11、 3の画像 3
    • Disconnect white connector by pushing down on the release tab while gently pulling the connector free from the socket.
    • Remove wiring harness and set aside.
    • The other connectors in the wiring harness should already be free from previous steps.
  12. Samsung Radiant 360 R1 Bluetooth Module Replacement: 手順 12、 2の画像 1 Samsung Radiant 360 R1 Bluetooth Module Replacement: 手順 12、 2の画像 2
    • Locate and remove the two PH2 Phillips screws from the base of the motherboard assembly.
    • These screws may be extremely tight. Be careful not to snap the plastic when removing the screws.
  13. Samsung Radiant 360 R1 Bluetooth Module Replacement: 手順 13、 2の画像 1 Samsung Radiant 360 R1 Bluetooth Module Replacement: 手順 13、 2の画像 2
    • Flip the motherboard assembly over and locate the Bluetooth module on the side of the metal frame.
    • Remove the one PH2 Philips screw.
  14. Samsung Radiant 360 R1 Bluetooth Module Replacement: 手順 14、 1の画像 1
    • Press the white tab while gently pulling the Bluetooth module away from the connector and frame.
終わりに
作成者
4人の作成者と共同で作成されました。
Daniel Mendoza
メンバー登録日: 02/01/17
101 ポイント
1ガイドが承認済み
チーム
UW Tacoma, Team 2-5, Rose Winter 2017 UW Tacoma, Team 2-5, Rose Winter 2017人のメンバー
UWT-ROSE-W17S2G5
4 メンバー
4のガイドは作成済み
4 件のコメント
Nice write up, but where does one obtain a new Bluetooth module for one of these?
Royce Courtney - 返信
Where can I buy these type of bluetooth module? Ty
Payout PH - 返信
Bluetooth module model is WIBT30D. You can google for it. It cost ~30 euro now
Salar Mahdavi - 返信
You all seem to know your way around these devices. Do you think it's possible to create an 'aux' style connection to allow wired playback? If WiFi and Bluetooth are failing, having the ability to connect to connect via wire would be really good.
Fred Tuinstra - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 1,079
