はじめに
This guide will show how you to replace a Samsung RF263BEAESR freezer door handle. Before you start working on the refrigerator make sure to unplug it. You will need a screw driver and an Alan key to complete this guide. Some of the steps might seem hard for example in step 2 and 3, you will need to screw in the screw on the door handle. You will need to make sure the screw is set perfectly for it to go in. I have made the steps as easy as possible which will help people save a lot of time.
必要な工具と部品
2 の人々がこのガイドを完成させました。
5 件のコメント
The plastic piece that you screw the mounting screw into is broken on our refrigerator. How can I open up the door to replace that plastic piece? Thanks.
Hi Kevin, were you able to fix the plastic piece. I also have a similar issue where the plastic broke off
According to Samsung, that 'plastic piece', also known as the Freezer Door Handle Mounting Cap, (the part that the handle mounting stud is attached through), has no part number... "There are not part numbers assigned to these parts as this model doesn’t allow the replacement of them". The only part option Samsung offers is the Freezer Door Assembly, currently about $350 plus Sales Tax and Shipping.
Once your Samsung appliance gets to be more than 2 or 3 years old, Samsung simply has horrible customer support and unreliable parts support for it's products.
