メインコンテンツにスキップ
Samsung RC512 Cooling Fan/Heat Sink Replacement
必要な工具と部品
  1. Samsung RC512 Cooling Fan/Heat Sink Replacement, Battery: 手順 1、 1の画像 1
    • Place the laptop upside down.
  2. Samsung RC512 Cooling Fan/Heat Sink Replacement: 手順 2、 2の画像 1 Samsung RC512 Cooling Fan/Heat Sink Replacement: 手順 2、 2の画像 2
    • Locate two notches above the battery.
    • Slide both battery locking notches to either side to remove the battery.
    • Pull the battery out.
  3. Samsung RC512 Cooling Fan/Heat Sink Replacement, Back Panel: 手順 3、 3の画像 1 Samsung RC512 Cooling Fan/Heat Sink Replacement, Back Panel: 手順 3、 3の画像 2 Samsung RC512 Cooling Fan/Heat Sink Replacement, Back Panel: 手順 3、 3の画像 3
    • Using the Phillips #0 screwdriver, unscrew the one 5mm screw.
    • Using the blue plastic opening tools, wedge one in between the back panel and the laptop.
    • Carefully remove the back panel..
  4. Samsung RC512 Cooling Fan/Heat Sink Replacement, HDD: 手順 4、 1の画像 1
    • Carefully lift the HDD up using plastic opening tool.
  5. Samsung RC512 Cooling Fan/Heat Sink Replacement: 手順 5、 1の画像 1
    • Grab the HDD and connector.
    • Carefully pull the HDD away from the connector.
  6. Samsung RC512 Cooling Fan/Heat Sink Replacement: 手順 6、 1の画像 1
    • Take out the HDD and leave the connector in the laptop
  7. Samsung RC512 Cooling Fan/Heat Sink Replacement, Optic Drive: 手順 7、 1の画像 1
    • Remove the 4mm Phillips #0 screw using a Phillips #0 screwdriver.
  8. Samsung RC512 Cooling Fan/Heat Sink Replacement: 手順 8、 3の画像 1 Samsung RC512 Cooling Fan/Heat Sink Replacement: 手順 8、 3の画像 2 Samsung RC512 Cooling Fan/Heat Sink Replacement: 手順 8、 3の画像 3
    • Use the spudger or fingers to gently pull the optical drive out.
    • Slide the optic drive away from the laptop.
  9. Samsung RC512 Cooling Fan/Heat Sink Replacement, Cooling Fan/Heat Sink: 手順 9、 2の画像 1 Samsung RC512 Cooling Fan/Heat Sink Replacement, Cooling Fan/Heat Sink: 手順 9、 2の画像 2
    • Remove the eight 5mm Phillips #0 screws using a Phillips #0 driver.
    • Also remove the three 5mm Phillips #0 using a Phillips #0 driver.
  10. Samsung RC512 Cooling Fan/Heat Sink Replacement: 手順 10、 3の画像 1 Samsung RC512 Cooling Fan/Heat Sink Replacement: 手順 10、 3の画像 2 Samsung RC512 Cooling Fan/Heat Sink Replacement: 手順 10、 3の画像 3
    この手順で使用する道具:
    購入する
    • Remove three bottom dark covers using tweezers.
    • Remove three 10mm Phillips #0 screws using Phillips #0 driver.
  11. Samsung RC512 Cooling Fan/Heat Sink Replacement: 手順 11、 2の画像 1 Samsung RC512 Cooling Fan/Heat Sink Replacement: 手順 11、 2の画像 2
    • Insert a plastic opening tool into the back cover and the housing of the body.
    • Use the plastic opening tool to pop open the clamps that hold the casing onto the back cover.
    • Work your way around the all sides to completely take off the back cover.
    • You may use your fingers to help remove the cover.
    • Carefully lift the back cover. Do not use excessive force to lift it. If it feels like it will not pull up, make sure all the screws have been taken out.
  12. Samsung RC512 Cooling Fan/Heat Sink Replacement: 手順 12、 3の画像 1 Samsung RC512 Cooling Fan/Heat Sink Replacement: 手順 12、 3の画像 2 Samsung RC512 Cooling Fan/Heat Sink Replacement: 手順 12、 3の画像 3
    • Remove two 5mm Phillips #8 screw using a phillips #0 screwdriver.
    • Gently pull out the connector from the motherboard.
  13. Samsung RC512 Cooling Fan/Heat Sink Replacement: 手順 13、 2の画像 1 Samsung RC512 Cooling Fan/Heat Sink Replacement: 手順 13、 2の画像 2
    • Remove the six 5mm Phillips #0 screw using a Phillips #0 screwdriver.
    • Gently lift the cooling fan and heat sink to take them off.
    • Heat sink might be hot right after the laptop is shutdown.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
jando
メンバー登録日: 09/15/16
896 ポイント
8のガイドは作成済み
チーム
USF Tampa, Team 18-2, Blackwell Fall 2016 USF Tampa, Team 18-2, Blackwell Fall 2016人のメンバー
USFT-BLACKWELL-F16S18G2
4 メンバー
8のガイドは作成済み
コメント 1 件
Thanks for the graphics. But you missed 3 screws under the battery compartment.
Doing all of this really helped... before, my laptop would just turn off randomly. I'm thinking this was because of overheating.
After this, it hasn't shut down yet.
thank you.
gary.crump - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 15
今までの合計 1,289
