はじめに
Hello everyone, in this guide I`ll be showing you how to open the laptop in order to change the keyboard.
Unscrew all the screws holding the back panel in place.
Remove the battery and the small panel to reveal more screws.
Remove the HDD and RAM.
Slide out the DVD drive.
Unscrew the heatsink and fan assembly. Disconnect the fan and remove it.
Remove the screws that hold the motherboard in place
Disconnect the touchpad, keyboard, USB module and Wi-Fi module.
Disconnect the power, screen and speaker connectors.
Unscrew the hinges and remove the display.
Remove the motherboard.
Peel and remove the black cover.
Use a soldering iron with a big tip, to melt the plastic rivets that hold the metal case for the keyboard.
Use a prying tool the remove the metal case.
Remove the old keyboard, place the new one and dont forget to place the metal case on top of it.
You can reuse the black cover is you want.
ある他の人がこのガイドを完成しました。
