メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
This guide will demonstrate careful steps to remove the motherboard from the phone without damaging the the interconnection parts.
  1. Press down the back and push up to remove back cover.
    • Press down the back and push up to remove back cover.
    • Insert finger into gap at the top left and remove battery.
  2. Use flat-head screwdriver to remove back lid.
    • Use flat-head screwdriver to remove back lid.
  3. Locate the six screws and remove them with Phillips #00 Screwdriver.
    • Locate the six screws and remove them with Phillips #00 Screwdriver.
  4. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
    • Insert the flat-head screwdriver into the crevice.
    • Slide and dislodge snap-ons under.
    • Remove the back frame.
  5. Locate and remove the six screws with Phillips #00 Screwdriver.
    • Locate and remove the six screws with Phillips #00 Screwdriver.
    • Separate the black middle frame from the front frame.
    • Be careful not to tear the phone bus.
  6. Locate and remove the four screws with Phillips #00 Screwdriver.
    • Locate and remove the four screws with Phillips #00 Screwdriver.
    • Slide the flat-head screwdriver and dislodge the snap-ons under.
    • Be careful not to rip the band.
  7. Use hands to remove both phone buses from the linkages, and remove motherboard.
    • Use hands to remove both phone buses from the linkages, and remove motherboard.
終わりに
Minh
メンバー登録日: 2011年04月28日
201 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 1-3, Nelson Spring 2011 CSU Los Angeles, Team 1-3, Nelson Spring 2011人のメンバー
CSULA-NELSON-S11S1G3
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,541
