メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
If the speaker phone functionality is not performing correctly, then it may be time to replace the external speaker phone. Follow this guide in order to check for damage, and, if necessary, replace the external speaker phone.
パーツ
パーツは指定されていません。
  1. Slide the battery out from the battery compartment on the back of the phone. Slide the battery out from the battery compartment on the back of the phone.
    • Slide the battery out from the battery compartment on the back of the phone.
  2. Unscrew the antenna top. Unscrew the antenna top.
    • Unscrew the antenna top.
  3. Clasp the antenna with tweezers and push toward the top. Remove the antenna. Remove the antenna.
    • Clasp the antenna with tweezers and push toward the top.
    • Remove the antenna.
  4. 今あるものを使い続けましょう
    オールインワインキットで安く修理して、節約しましょう。
    iPhone 修理キットを見る
    今あるものを使い続けましょう
    iPhone 修理キットを見る
  5. Remove the four screws (3 mm) from the battery compartment. Press the release buttons located on the side of the phone while gently prying the back plate off. Press the release buttons located on the side of the phone while gently prying the back plate off.
    • Remove the four screws (3 mm) from the battery compartment.
    • Press the release buttons located on the side of the phone while gently prying the back plate off.
  6. Press the release tabs on the sides of the back casing. Gently pry the motherboard loose and remove it. Gently pry the motherboard loose and remove it.
    • Press the release tabs on the sides of the back casing.
    • Gently pry the motherboard loose and remove it.
  7. Locate the back plate of the phone. Turn the back plate over to view the inside. Remove the 2 mm screw from the top of the inner back casing of the phone. Remove the 2 mm screw from the top of the inner back casing of the phone.
    • Locate the back plate of the phone. Turn the back plate over to view the inside.
    • Remove the 2 mm screw from the top of the inner back casing of the phone.
  8. With the flat head screwdriver, remove the external speaker unit. With the flat head screwdriver, remove the external speaker unit.
    • With the flat head screwdriver, remove the external speaker unit.
  9. Take the external speaker unit and turn it over. Remove the black rubber casing.
    • Take the external speaker unit and turn it over.
    • Remove the black rubber casing.
  10. Use tweezers to remove the external speaker from the small unit. Use tweezers to remove the external speaker from the small unit.
    • Use tweezers to remove the external speaker from the small unit.
終わりに
Barbara
メンバー登録日: 2014年03月26日
413 ポイント
4のガイドは作成済み
チーム
Clemson, Team 6-2, Benson Spring 2014 Clemson, Team 6-2, Benson Spring 2014人のメンバー
CLEM-BENSON-S14S6G2
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 177
