メインコンテンツにスキップ
Samsung POWERbot VR9000 Left Driving Wheel Replacement
必要な工具と部品
  1. Samsung POWERbot VR9000 Left Driving Wheel Replacement, Top Chassis: 手順 1、 2の画像 1 Samsung POWERbot VR9000 Left Driving Wheel Replacement, Top Chassis: 手順 1、 2の画像 2
    • Turn off the emergency switch located at the bottom right of the POWERbot.
  2. Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 2、 2の画像 1 Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 2、 2の画像 2
    • Insert the plastic opening tool under the black cover, near the Samsung logo on the back of the device, and partially pry open.
  3. Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 3、 2の画像 1 Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 3、 2の画像 2
    • Slide the plastic opening tool to the left, remaining under the black cover, until two left side pins have been detached. Then slide the plastic opening tool to the right until two right side pins have been detached.
    • Grab the two clips near the front of the black cover, on in front of each wheel. Pull the clips away from the wheels.
  4. Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 4、 3の画像 1 Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 4、 3の画像 2 Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 4、 3の画像 3
    • Remove the black cover.
  5. Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 5、 2の画像 1 Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 5、 2の画像 2
    • Insert the plastic opening tool under copper-colored cover, under the words "CycloneForce," and pry open, applying a small rotation, until the two pins are released .
    • Grab the underside of the cover and lift upwards while pushing forward until the cover pops off.
  6. Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 6、 2の画像 1 Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 6、 2の画像 2
    • Remove the three 6mm Phillips #1 screws in the holes near the back of the device.
  7. Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 7、 2の画像 1 Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 7、 2の画像 2
    • Remove the 6mm Phillips #1 screw in the hole that was under the copper-colored vacuum cover.
  8. Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 8、 2の画像 1 Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 8、 2の画像 2
    • Flip the device over and remove the 6mm Phillips #1 screw in front of the left (from this perspective, right) wheel.
  9. Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 9、 2の画像 1 Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 9、 2の画像 2
    • Detach the wider circuit connector by pressing down gently on the left end of the clip and pulling the connector out.
    • Pull the connector out by the top and bottom of the white piece and not by the wires.
  10. Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 10、 2の画像 1 Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 10、 2の画像 2
    • Remove the top chassis from the POWERbot by grabbing the wheel covers and lifting upwards.
  11. Samsung POWERbot VR9000 Left Driving Wheel Replacement, Left Driving Wheel: 手順 11、 2の画像 1 Samsung POWERbot VR9000 Left Driving Wheel Replacement, Left Driving Wheel: 手順 11、 2の画像 2
    • Remove the two 5mm Phillips #1 screws in the holes closest to the left wheel.
  12. Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 12、 2の画像 1 Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 12、 2の画像 2
    • Detach the top-most circuit connector on the left side by pressing down gently on the left end of the clip and pulling the connector out.
  13. Samsung POWERbot VR9000 Left Driving Wheel Replacement: 手順 13、 1の画像 1
    • Remove the driving wheel assembly from the POWERbot by grabbing the wheel and lifting upwards.
終わりに
26 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Kyle Chin
メンバー登録日: 04/24/17
1,919 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S15-G3, Banghart Spring 2017 Cal Poly, Team S15-G3, Banghart Spring 2017人のメンバー
CPSU-BANGHART-S17S15G3
4 メンバー
14のガイドは作成済み
9 件のコメント
Thanks for the info but can you tell me where I can get the wheel assembly as I think the motor has burned out. Thanks
Stephen Rawlings - 返信
Thank you so much :) … You helped me save all the money that I have spent on the Samsung Powerbot as I thought there is no way to fix it !
Can't Thank you enough Kyle ;)
shiraku gori - 返信
Thanks for your information, also I would like to find the spare parts of wheel assembly . Can you recommend me for seller and prices?
October 23, 2018
Narit pukkapan
Rubber Tree - 返信
Thank you for the usefull instructions. The problem was the wheel engine broken. I’ve been surprised that it was not brushless. Now I will try to fix it. Have a nice time
David - 返信
Thank you for your instructions. I open it up and clean the left wheel decoder by blowing air thru it. Put it back and it run as new. Thank you again.
Uyen Vo - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 21
過去 30 日: 49
今までの合計 18,367
