メインコンテンツにスキップ
Samsung POWERbot R7070 Vacuum Motor Replacement
必要な工具と部品
  1. Samsung POWERbot R7070 Vacuum Motor Replacement, Battery: 手順 1、 1の画像 1
    • Turn the emergency switch off.
  2. Samsung POWERbot R7070 Vacuum Motor Replacement: 手順 2、 2の画像 1 Samsung POWERbot R7070 Vacuum Motor Replacement: 手順 2、 2の画像 2
    • Remove the two exposed screws on the top right of the device.
  3. Samsung POWERbot R7070 Vacuum Motor Replacement: 手順 3、 1の画像 1
    • Lift the cover plate to expose the battery.
  4. Samsung POWERbot R7070 Vacuum Motor Replacement: 手順 4、 2の画像 1 Samsung POWERbot R7070 Vacuum Motor Replacement: 手順 4、 2の画像 2
    • Using one hand, pinch the white plastic connector where the battery's wiring connects the POWERbot. Pull up to disconnect.
  5. Samsung POWERbot R7070 Vacuum Motor Replacement: 手順 5、 2の画像 1 Samsung POWERbot R7070 Vacuum Motor Replacement: 手順 5、 2の画像 2
    • Lift the battery from the right side, up and out of its compartment.
  6. Samsung POWERbot R7070 Vacuum Motor Replacement, Motor: 手順 6、 2の画像 1 Samsung POWERbot R7070 Vacuum Motor Replacement, Motor: 手順 6、 2の画像 2
    • Unscrew the two silver 1.5 cm screws on the left and right side of the battery compartment.
    • Remove the two 1.5 cm screws above the yellow sliding lock tabs.
    • Remove the two 1.2 cm screws in the brush compartment.
  7. Samsung POWERbot R7070 Vacuum Motor Replacement: 手順 7、 2の画像 1 Samsung POWERbot R7070 Vacuum Motor Replacement: 手順 7、 2の画像 2
    • With moderate force, separate the silver top from the black bottom of the vacuum.
    • The cover will only separate a few inches as the two halves are connected by wires.
  8. Samsung POWERbot R7070 Vacuum Motor Replacement: 手順 8、 1の画像 1
    • Disconnect the white and red wired connector attached to the top half of the base of the vacuum by squeezing the connector and pulling up.
  9. Samsung POWERbot R7070 Vacuum Motor Replacement: 手順 9、 1の画像 1
    • Pinching the top and bottom of the black wired connector, pull outward, fully detaching the top from the bottom of the device.
  10. Samsung POWERbot R7070 Vacuum Motor Replacement: 手順 10、 1の画像 1
    • Detach the wide circuit connector on the left side by pinching and pressing down on the right and left side of the clip, pulling the connector out.
    • Pull the connector out by the left and right side of the white clip and not by the wires.
  11. Samsung POWERbot R7070 Vacuum Motor Replacement: 手順 11、 2の画像 1 Samsung POWERbot R7070 Vacuum Motor Replacement: 手順 11、 2の画像 2
    • Remove the four 1.2 cm screws.
    • Remove the single 0.8 cm screw.
  12. Samsung POWERbot R7070 Vacuum Motor Replacement: 手順 12、 1の画像 1
    • Remove the two 1.5 cm screws on the motor chamber.
  13. Samsung POWERbot R7070 Vacuum Motor Replacement: 手順 13、 2の画像 1 Samsung POWERbot R7070 Vacuum Motor Replacement: 手順 13、 2の画像 2
    • Lift the motor by grabbing the body of the motor, lifting upward.
    • With the screws removed from the motor chamber the top of the motor chamber will pop open.
終わりに
8 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Eric Anderson
メンバー登録日: 09/11/17
465 ポイント
2のガイドは作成済み
チーム
CSU Fullerton, Team S2-G8, Bruce Fall 2017 CSU Fullerton, Team S2-G8, Bruce Fall 2017人のメンバー
CSUF-BRUCE-F17S2G8
3 メンバー
10のガイドは作成済み
6件のガイドコメント
Anybody know where I can get the motor?
donstatus87 - 返信
I'm getting a Power brush error. Does the motor contain the power brush square socket and gearing?
Steve.
Steven Nicholas - 返信
One can actually open up the motor housing and take out the metal motor. Be careful not to break the clips when opening the housing… because I did…. but duct tape will prolly hold it together again. Anyway , the motor bears the following markings in my R7040: VCM-140CLDA DC21.6V 145W 2018.5.22-12.50
Have fun!
websites140 - 返信
Easy to replace and found a refurbished motor on eBay.
David Trinkle - 返信
Thanks for this guide! My motor was making a high pitched whine and grind - bought a replacement refurb motor on eBay for $39; hope it works.
joey - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 21
今までの合計 4,271
