メインコンテンツにスキップ
Samsung PL200 Battery Replacement
  1. Samsung PL200 Battery Replacement, Battery: 手順 1、 2の画像 1 Samsung PL200 Battery Replacement, Battery: 手順 1、 2の画像 2
    • Flip Samsung PL200 over to access battery/SD card compartment on the bottom. There is a sliding release button (labeled 'OPEN') that can be slid sideways to open the battery/SD card compartment.
    • Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/SD card compartment door. Once opened, the battery should be visible.
  2. Samsung PL200 Battery Replacement: 手順 2、 3の画像 1 Samsung PL200 Battery Replacement: 手順 2、 3の画像 2 Samsung PL200 Battery Replacement: 手順 2、 3の画像 3
    • Once the battery/SD card compartment is opened, in order to remove the battery, you must push the small blue release button.
    • This will release the spring loaded battery.
    • Use your fingers to remove the old battery.
  3. Samsung PL200 Battery Replacement: 手順 3、 3の画像 1 Samsung PL200 Battery Replacement: 手順 3、 3の画像 2 Samsung PL200 Battery Replacement: 手順 3、 3の画像 3
    • Insert the new battery into the battery slot.
    • Push it down with your finger until the blue release switch re-engages over top of the battery.
    • Close the battery/SD card compartment.
終わりに
After replacing the battery, be sure to connect your charger cable and charge the new battery fully before using it.
作成者
2人の作成者と共同で作成されました。
Austin Fitzpatrick
メンバー登録日: 01/29/15
110 ポイント
1ガイドが承認済み
チーム
Clemson, Team 15-7, Shirley Winter 2015 Clemson, Team 15-7, Shirley Winter 2015人のメンバー
CLEM-SHIRLEY-W15S15G7
5 メンバー
9のガイドは作成済み
2 件のコメント
Is the battery dead? Can Samsung indicate wher new batteries are sold? Camera retailers are rare, these days
Reginald Parker - 返信
No-one can find a contact address for Samsung spares. New smartphones, no problem! Thank you for trying. I just have to keep looking! Reg
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 25
今までの合計 1,056
