メインコンテンツにスキップ
Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement
必要な工具と部品
  1. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement, Battery: 手順 1、 1の画像 1
    • Flip your laptop over so that the back is face up.
  2. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 手順 2、 2の画像 1 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 手順 2、 2の画像 2
    • Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
  3. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 手順 3、 2の画像 1 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 手順 3、 2の画像 2
    • Use a plastic opening tool to remove the back plate from the laptop.
    • It is recommended that you start from a corner then run the tool along the edge of the back plate.
  4. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 手順 4、 2の画像 1 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 手順 4、 2の画像 2
    • Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
  5. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 手順 5、 3の画像 1 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 手順 5、 3の画像 2 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 手順 5、 3の画像 3
    • Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
    • Using the metal spudger may severely damage the internal components in your device.
  6. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement, Hard Drive and SSD: 手順 6、 1の画像 1
    • Remove the connection cable from the hard drive.
  7. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 手順 7、 1の画像 1
    • Use a Phillips #00 to remove four screws from the hard drive cradle.
  8. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 手順 8、 1の画像 1
    • Pull the hard drive away from the cradle and remove it from the device.
終わりに
作成者
3人の作成者と共同で作成されました。
Minje Sa
メンバー登録日: 09/16/19
113 ポイント
1ガイドが承認済み
チーム
2 件のコメント
Would you point out where the SSD slot would be?
aroyphillips - 返信
this was very helpfull!, im not sure where i could find the SSD though
Kaleb Miller - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 22
今までの合計 3,594
