この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will show you how to remove the back panel assembly, which houses the main control buttons and the LED display, allowing to replace its individual parts or access the internal parts of part of the camera.
必要な工具と部品
Using a Phillips #00 precision screwdriver, remove the seven 4mm screws (5 on the bottom of the device and 1 on each of the two sides) holding the back panel to the camera.
In NX300M, there is an additional screw under the text AMOLED behind display which should be removed before detaching the back panel of the camera.
Using a Phillips #00 precision screwdriver, remove the last 4mm screw located inside the input ports' compartment.
Place a plastic opening tool into the gap between the back panel and camera body, from both the top and the bottom of camera. Carefully pry open the camera and separate the back panel.
Using tweezers or your fingers, pull the display's black ribbon from the motherboard. This frees the back panel altogether.
11 の人々がこのガイドを完成させました。
2 件のコメント
I had to replace the back panel when my amoled screen started going bad. Thanks for a great tutorial!
Hello, can anybody tell me if the display of SAMSUNG NX 300 M match to a SAMSUNG NX 300 ? I need to replace the display of NX 300 and i dont find any pieces but i found an NX 300 M
