メインコンテンツにスキップ
Samsung NX300 and NX300M Back Panel Assembly Replacement
必要な工具と部品
  1. Samsung NX300 and NX300M Back Panel Assembly Replacement, Unscrew the Back Panel: 手順 1、 2の画像 1 Samsung NX300 and NX300M Back Panel Assembly Replacement, Unscrew the Back Panel: 手順 1、 2の画像 2
    • Using a Phillips #00 precision screwdriver, remove the seven 4mm screws (5 on the bottom of the device and 1 on each of the two sides) holding the back panel to the camera.
    • On the NX300M model, there is an additional screw under the text AMOLED behind display which should be removed before detaching the back panel of the camera.
  2. Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Input Port Screw: 手順 2、 1の画像 1
    • Using a Phillips #00 precision screwdriver, remove the last 4 mm screw located inside the input ports' compartment.
    I've tried this before and I remember this screw not coming off why is this?
    Jun Hong - 返信
    Hello Jun. If you are using the correct screwdriver, there may be a few answers to your question:
    The camera screw is stuck:
    This happened to the team that did this project, just keep working with the screwdriver until it comes loose.
    The camera screw lost threads:
    If a screw is screwed in incorrectly, it could be permanently lodged in the camera and you will be unable to open it.
    The camera screw head is rounded:
    If the small pieces of the head (visible) part of the screw are gone with groove marks, the screw is permanently damaged and cannot be removed unless you have special equipment.
    Other than these tips, you may need to look elsewhere for more help.
    -Victoria
    Victoria Leppold - 返信
    Thank you for the quick reply! Does this have to do with it being the last screw to be taken out? do the screws have to be screwed out in this order? Thank you
    Jun Hong -
    There is no order for removing the screws. However, we did take note it was the most difficult to remove because of it's placement. It is difficult to get a grip on the camera when attempting to loosen this screw, therefore it is more prone to damage. Keep trying, but don't force the screw out to where the part may become damaged by means listed in the previous comment.
    -Victoria
  3. Samsung NX300 and NX300M Back Panel Assembly Replacement, Open the Camera Casing: 手順 3、 3の画像 1 Samsung NX300 and NX300M Back Panel Assembly Replacement, Open the Camera Casing: 手順 3、 3の画像 2 Samsung NX300 and NX300M Back Panel Assembly Replacement, Open the Camera Casing: 手順 3、 3の画像 3
    • Place a plastic opening tool into the gap between the back panel and camera body, from both the top and the bottom of camera. Carefully pry open the camera and separate the back panel.
  4. Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Back Panel: 手順 4、 3の画像 1 Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Back Panel: 手順 4、 3の画像 2 Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Back Panel: 手順 4、 3の画像 3
    • Using tweezers or your fingers, pull the display's black ribbon from the motherboard. This frees the back panel altogether.
    • To safely remove ribbons, you would need to first unlock the holding mechanism by lifting up the black strip atop the ribbon adapter.
    Hi, I have follow the 4 steps and now my question is about the proper lcd screem. In my case the touch "cristal" is broke do I have to buy all the back side of the camara (with the keys, I mean) o can I take off only the "cristal". I saw in Aliexpress taht they sell all the piece or the "cristal" alone. I do not know how to take out the broken cristal from the back piece. please can you help me. Sorry by my english I am Spanish and I do not now if I did explain properly. Thank you.
    cvaragarcia - 返信
    How can I buy this back panel assembly?
    Mail me : saroch501@gmail.com
    Big thanks.
    Saroch Kongwat - 返信
終わりに
11 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Andres Perez
メンバー登録日: 01/21/15
951 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 9-6, Blackwell Winter 2015 USF Tampa, Team 9-6, Blackwell Winter 2015人のメンバー
USFT-BLACKWELL-W15S9G6
4 メンバー
10のガイドは作成済み
2 件のコメント
I had to replace the back panel when my amoled screen started going bad. Thanks for a great tutorial!
Amanda Aiken - 返信
Hello, can anybody tell me if the display of SAMSUNG NX 300 M match to a SAMSUNG NX 300 ? I need to replace the display of NX 300 and i dont find any pieces but i found an NX 300 M
Norbert - Ciprian Patras - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 23
今までの合計 4,997
