メインコンテンツにスキップ
Samsung NX300 and NX300M Back Panel Assembly Replacement
必要な工具と部品
  1. Samsung NX300 and NX300M Back Panel Assembly Replacement, Unscrew the Back Panel: 手順 1、 2の画像 1 Samsung NX300 and NX300M Back Panel Assembly Replacement, Unscrew the Back Panel: 手順 1、 2の画像 2
    • Using a Phillips #00 precision screwdriver, remove the seven 4mm screws (5 on the bottom of the device and 1 on each of the two sides) holding the back panel to the camera.
    • On the NX300M model, there is an additional screw under the text AMOLED behind display which should be removed before detaching the back panel of the camera.
  2. Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Input Port Screw: 手順 2、 1の画像 1
    • Using a Phillips #00 precision screwdriver, remove the last 4 mm screw located inside the input ports' compartment.
  3. Samsung NX300 and NX300M Back Panel Assembly Replacement, Open the Camera Casing: 手順 3、 3の画像 1 Samsung NX300 and NX300M Back Panel Assembly Replacement, Open the Camera Casing: 手順 3、 3の画像 2 Samsung NX300 and NX300M Back Panel Assembly Replacement, Open the Camera Casing: 手順 3、 3の画像 3
    • Place a plastic opening tool into the gap between the back panel and camera body, from both the top and the bottom of camera. Carefully pry open the camera and separate the back panel.
  4. Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Back Panel: 手順 4、 3の画像 1 Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Back Panel: 手順 4、 3の画像 2 Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Back Panel: 手順 4、 3の画像 3
    • Using tweezers or your fingers, pull the display's black ribbon from the motherboard. This frees the back panel altogether.
    • To safely remove ribbons, you would need to first unlock the holding mechanism by lifting up the black strip atop the ribbon adapter.
終わりに
11 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Andres Perez
メンバー登録日: 01/21/15
951 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 9-6, Blackwell Winter 2015 USF Tampa, Team 9-6, Blackwell Winter 2015人のメンバー
USFT-BLACKWELL-W15S9G6
4 メンバー
10のガイドは作成済み
2 件のコメント
I had to replace the back panel when my amoled screen started going bad. Thanks for a great tutorial!
Amanda Aiken - 返信
Hello, can anybody tell me if the display of SAMSUNG NX 300 M match to a SAMSUNG NX 300 ? I need to replace the display of NX 300 and i dont find any pieces but i found an NX 300 M
Norbert - Ciprian Patras - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 20
今までの合計 4,977
