メインコンテンツにスキップ
Samsung NX2000 Menu Buttons Replacement
必要な工具と部品
  1. Samsung NX2000 Menu Buttons Replacement, LCD: 手順 1、 1の画像 1
    • First begin by flipping your camera upside down.
    • Remove the seven 4mm screws from indicated circles shown using a Y0 screwdriver. There are three on the bottom, and two on each side
    • Remember to store the screws in a secure place.
  2. Samsung NX2000 Menu Buttons Replacement: 手順 2、 3の画像 1 Samsung NX2000 Menu Buttons Replacement: 手順 2、 3の画像 2 Samsung NX2000 Menu Buttons Replacement: 手順 2、 3の画像 3
    • Insert a plastic opening tool into the gab between the camera body and the back panel. Carefully pry open the camera and separate the back panel.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
  3. Samsung NX2000 Menu Buttons Replacement: 手順 3、 3の画像 1 Samsung NX2000 Menu Buttons Replacement: 手順 3、 3の画像 2 Samsung NX2000 Menu Buttons Replacement: 手順 3、 3の画像 3
    • Before taking it apart you'll have to detach the display ribbon cable.
    • Use a plastic opening tool, lift up the black strip to release the ribbon cable from the connector.
  4. Samsung NX2000 Menu Buttons Replacement: 手順 4、 3の画像 1 Samsung NX2000 Menu Buttons Replacement: 手順 4、 3の画像 2 Samsung NX2000 Menu Buttons Replacement: 手順 4、 3の画像 3
    • Separate the LCD half compartment of the camera from the main body.
  5. Samsung NX2000 Menu Buttons Replacement: 手順 5、 1の画像 1
    • Remove the four 1mm screws with the Y0 screwdriver.
  6. Samsung NX2000 Menu Buttons Replacement: 手順 6、 3の画像 1 Samsung NX2000 Menu Buttons Replacement: 手順 6、 3の画像 2 Samsung NX2000 Menu Buttons Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    • Use a plastic opening tool or tweezers to lift the green tape located on top of the LCD controller board.
    • Detach the two ribbon cables, by first lifting the black tab on top of the connector.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  7. Samsung NX2000 Menu Buttons Replacement: 手順 7、 3の画像 1 Samsung NX2000 Menu Buttons Replacement: 手順 7、 3の画像 2 Samsung NX2000 Menu Buttons Replacement: 手順 7、 3の画像 3
    • Place blue plastic spudger in between LCD screen and plastic surrounding.
    • Begin to lift up slowly, removing the LCD screen from the main frame.
  8. Samsung NX2000 Menu Buttons Replacement: 手順 8、 1の画像 1
    • The LCD screen is now separated form the main frame.
  9. Samsung NX2000 Menu Buttons Replacement, Menu Buttons: 手順 9、 3の画像 1 Samsung NX2000 Menu Buttons Replacement, Menu Buttons: 手順 9、 3の画像 2 Samsung NX2000 Menu Buttons Replacement, Menu Buttons: 手順 9、 3の画像 3
    この手順で使用する道具:
    • Use the tweezers to pull out the home and playback buttons from the camera frame.
  10. Samsung NX2000 Menu Buttons Replacement: 手順 10、 1の画像 1
    • Remove the home buttons from the camera frame.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Katarina Raic
メンバー登録日: 02/09/16
288 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 7-4, Cheng Spring 2016 USF Tampa, Team 7-4, Cheng Spring 2016人のメンバー
USFT-CHENG-S16S7G4
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 12
今までの合計 573
