メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This guide will show you how to access the sensor for cleaning or necessary repairs.
  1. Orient the camera so the button panel and LCD are facing you. Use a spudger or fingernail to open the battery compartment on the right side of the camera. Use a spudger or fingernail to open the battery compartment on the right side of the camera.
    • Orient the camera so the button panel and LCD are facing you.
    • Use a spudger or fingernail to open the battery compartment on the right side of the camera.
  2. Push the blue trapdoor to the left to release the battery, and remove the battery. There is no battery shown in this photo.
    • Push the blue trapdoor to the left to release the battery, and remove the battery.
    • There is no battery shown in this photo.
    my battery is stuck, is there a manual release button or a way to remove the battery safely?
    beat70 - 返信
  3. Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
    • Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
  4. Remove the 4 mm Phillips #00 screw hiding in the external flash port.
    • Remove the 4 mm Phillips #00 screw hiding in the external flash port.
  5. Remove the four 5 mm Phillips #00 screws from the lens assembly.
    • Remove the four 5 mm Phillips #00 screws from the lens assembly.
  6. 今あるものを使い続けましょう
    オールインワインキットで安く修理して、節約しましょう。
    iPhone 修理キットを見る
    今あるものを使い続けましょう
    iPhone 修理キットを見る
  7. Remove the metal lens mount by hand or with tweezers.
    • Remove the metal lens mount by hand or with tweezers.
    • Be careful not to touch the sensor in the center of the lens assembly.
  8. Use tweezers to remove the inner metal ring.
    • Use tweezers to remove the inner metal ring.
  9. Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
  10. Use your hands to slowly pull the front casing away from the camera. The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
    • Use your hands to slowly pull the front casing away from the camera.
    • The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
  11. Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable. Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover. Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
    • Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
    • Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
    • Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
    • The gold lens contacts lying beneath the ribbon cable become loose when the screw and contact cover are removed.
  12. Remove the four 4 mm Phillips #00 screws holding the sensor mount in place. Remove the four 4 mm Phillips #00 screws holding the sensor mount in place.
    • Remove the four 4 mm Phillips #00 screws holding the sensor mount in place.
  13. Remove the four 4 mm Phillips #00 screws securing the battery compartment to the mother board. Remove the battery compartment. Remove the battery compartment.
    • Remove the four 4 mm Phillips #00 screws securing the battery compartment to the mother board.
    • Remove the battery compartment.
  14. Use a spudger to disconnect the ribbon cable connecting the image sensor to the motherboard. Use a spudger to disconnect the ribbon cable connecting the image sensor to the motherboard.
    • Use a spudger to disconnect the ribbon cable connecting the image sensor to the motherboard.
  15. Gently remove the sensor mount from the camera case.
    • Gently remove the sensor mount from the camera case.
終わりに
ある他の人がこのガイドを完成しました。
Kelsea Weber
メンバー登録日: 2015年11月12日
16,895 ポイント
32のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
128 メンバー
13,049のガイドは作成済み
コメント1件
Hello,
I need to know the exact dimensions of the IR-cut filter in the Samsung NX Mini camera, which should be just above the sensor. Could you possibly give me that information? I need that because I’d like to modify my NX Mini camera and change it into an infrared camera. I have to cut an infrared filter in the right size, before the disassembly of the camera.
Thank you!
Siamak ADN - 返信
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 7
今までの合計 782
