はじめに
This guide will show you how to access the sensor for cleaning or necessary repairs.
必要な工具と部品
Orient the camera so the button panel and LCD are facing you.
Use a spudger or fingernail to open the battery compartment on the right side of the camera.
Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
To reassemble your camera, follow these instructions in reverse order.
ある他の人がこのガイドを完成しました。
コメント 1 件
Hello,
I need to know the exact dimensions of the IR-cut filter in the Samsung NX Mini camera, which should be just above the sensor. Could you possibly give me that information? I need that because I’d like to modify my NX Mini camera and change it into an infrared camera. I have to cut an infrared filter in the right size, before the disassembly of the camera.
Thank you!
Siamak ADN - 返信
