はじめに
Use this guide to replace a damaged front case or open the case to access other components of your camera.
パーツ
パーツは指定されていません。
Orient the camera so the button panel and LCD are facing you.
Use a spudger or fingernail to open the battery compartment on the right side of the camera.
Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
もう少しです!
終わりに
