はじめに
This guide will show you how to remove the flash assembly in the Samsung NX Mini. The flash assembly includes the capacitor, so be sure to discharge the capacitor prior to removal. Learn more about discharging capacitors here.
必要な工具と部品
Orient the camera so the button panel and LCD are facing you.
Use a spudger or fingernail to open the battery compartment on the right side of the camera.
Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
Use a Phillips #00 screwdriver to remove the 3 mm screw located below the wifi antenna.
Use a Phillips #00 screwdriver to remove the two 5 mm screws holding the flash assembly to the camera case.
