メインコンテンツにスキップ
Samsung NP900X4B Wifi Card Replacement
必要な工具と部品
  1. Samsung NP900X4B Wifi Card Replacement, Wifi Card: 手順 1、 1の画像 1
    • This guide should be attempted after the removal of the back panel is completed.
    • The Battery Removal guide demonstrates how to do this. The link to this guide is posed here. Samsung NP900X4B Battery Replacement
  2. Samsung NP900X4B Wifi Card Replacement: 手順 2、 1の画像 1
    • In order to continue, you need to observe the inside of the laptop and find where the Wifi Card is located.
  3. Samsung NP900X4B Wifi Card Replacement: 手順 3、 1の画像 1
    • After finding the Wifi Card, you will discover two more 2.5mm Phillips #00 screws which hold the card in place.
    • The screws locations are shown in the image.
    • The same bit piece will be used to unscrew these (PH00/PH000). After completing this continue to the next step.
  4. Samsung NP900X4B Wifi Card Replacement: 手順 4、 2の画像 1 Samsung NP900X4B Wifi Card Replacement: 手順 4、 2の画像 2
    • There will be two wires connecting to the Wifi Card from the laptop.
    • These wires can be removed with one of the plastic tools in the iFixit toolkit by applying slight force onto them.
    • After removing the wires move on to the next step.
  5. Samsung NP900X4B Wifi Card Replacement: 手順 5、 2の画像 1 Samsung NP900X4B Wifi Card Replacement: 手順 5、 2の画像 2
    • This last step is the easiest of them all, all you need to do it pick up the Wifi Card from its position and you're done!
    • Now you are able to replace the card by following these steps in reverse or have the card further repaired.
終わりに
作成者
2人の作成者と共同で作成されました。
Jacob Drohan
メンバー登録日: 10/15/18
121 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S4-G6, Valliere Fall 2018 UMass Dartmouth, Team S4-G6, Valliere Fall 2018人のメンバー
UMASSD-VALLIERE-F18S4G6
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 217
