はじめに
In this guide you will be learning how to remove the hard drive from your Samsung NP5230U4BL laptop. This will enable you to replace a damaged hard driver. Before attempting to remove the hard drive, be sure to ground yourself with an anti-static wrist strap and have a Philips #00 Screwdriver, as well as a Nylon pry tool on standby. Also carefully follow the given instructions including the cautionary warnings.
必要な工具と部品
Using the Phillips #00 screwdriver, remove all ten 1.5 mm screws from the back cover of the laptop.
Hard Drive (not pictured)
Using your dominant hand, unplug the hard drive from its SATA plug. Once unplugged, the hard drive is an independent piece from the laptop.
ある他の人がこのガイドを完成しました。
