メインコンテンツにスキップ
Samsung NP36535C-S05US Display Screen Replacement
必要な工具と部品
  1. Samsung NP36535C-S05US Display Screen Replacement, Battery: 手順 1、 1の画像 1
    • Turn the computer off.
    • Disconnect the charging cable from the laptop.
    • Failure to disconnect cable may result in electric shock.
    • Flip the laptop face down on a flat surface.
  2. Samsung NP36535C-S05US Display Screen Replacement: 手順 2、 1の画像 1
    • Slide the left and right switches to the unlock position.
  3. Samsung NP36535C-S05US Display Screen Replacement: 手順 3、 2の画像 1 Samsung NP36535C-S05US Display Screen Replacement: 手順 3、 2の画像 2
    • While holding the left and right lock switches in the unlock position, pull the battery away from the computer.
  4. Samsung NP36535C-S05US Display Screen Replacement, Display Screen: 手順 4、 3の画像 1 Samsung NP36535C-S05US Display Screen Replacement, Display Screen: 手順 4、 3の画像 2 Samsung NP36535C-S05US Display Screen Replacement, Display Screen: 手順 4、 3の画像 3
    • Open the laptop.
    • Locate the two (2) screw covers.
    • Remove the screw covers with the metal spudger.
  5. Samsung NP36535C-S05US Display Screen Replacement: 手順 5、 1の画像 1
    • Remove the two (2) 2.27 mm screws with the Philips #0 screwdriver.
  6. Samsung NP36535C-S05US Display Screen Replacement: 手順 6、 1の画像 1
    • Carefully pry the front display cover off with a plastic prying tool.
  7. Samsung NP36535C-S05US Display Screen Replacement: 手順 7、 3の画像 1 Samsung NP36535C-S05US Display Screen Replacement: 手順 7、 3の画像 2 Samsung NP36535C-S05US Display Screen Replacement: 手順 7、 3の画像 3
    • Locate the six (6) 2.39 mm screws on the display bracket.
    • Remove the four (4) screws on the left and right sides of the display bracket located near the base of the display with the Philips #0 screwdriver.
    • Remove the two (2) screws on the left and right sides of the display bracket located near the top of the display with the Phillips #0 screwdriver.
  8. Samsung NP36535C-S05US Display Screen Replacement: 手順 8、 1の画像 1
    • Carefully remove the connector between the display and the display casing by pulling the connector away from its outlet.
  9. Samsung NP36535C-S05US Display Screen Replacement: 手順 9、 2の画像 1 Samsung NP36535C-S05US Display Screen Replacement: 手順 9、 2の画像 2
    • Locate the six (6) 1.85 mm screws on the left and right brackets holding the display in place.
    • Remove the screws on each side of the bracket, alternating sides when removing each screw with the Philips #0 screwdriver.
  10. Samsung NP36535C-S05US Display Screen Replacement: 手順 10、 3の画像 1 Samsung NP36535C-S05US Display Screen Replacement: 手順 10、 3の画像 2 Samsung NP36535C-S05US Display Screen Replacement: 手順 10、 3の画像 3
    • Locate the display connector on the back of the display.
    • Carefully remove the tape on the display connector.
    • Remove the display connector by unplugging it from its outlet.
  11. Samsung NP36535C-S05US Display Screen Replacement: 手順 11、 3の画像 1 Samsung NP36535C-S05US Display Screen Replacement: 手順 11、 3の画像 2 Samsung NP36535C-S05US Display Screen Replacement: 手順 11、 3の画像 3
    • Locate and remove the tape from the back of the display in the two (2) sections marked on the supporting image.
  12. Samsung NP36535C-S05US Display Screen Replacement: 手順 12、 1の画像 1
    • You have successfully removed the display screen.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Mykel Vanek
メンバー登録日: 09/21/17
334 ポイント
3のガイドは作成済み
チーム
Eastern Washington University, Team S2-G1, Crane Fall 2017 Eastern Washington University, Team S2-G1, Crane Fall 2017人のメンバー
EWU-CRANE-F17S2G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 386
