メインコンテンツにスキップ
Samsung NP305E5A-A03US Optical Drive Replacement
必要な工具と部品
  1. Samsung NP305E5A-A03US Optical Drive Replacement, Hard Drive: 手順 1、 1の画像 1
    • Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  2. Samsung NP305E5A-A03US Optical Drive Replacement: 手順 2、 1の画像 1
    • Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
    • Note this may take force. If you have difficulties using the plastic opening tool, try to use your hands to pull the panel off.
  3. Samsung NP305E5A-A03US Optical Drive Replacement: 手順 3、 2の画像 1 Samsung NP305E5A-A03US Optical Drive Replacement: 手順 3、 2の画像 2
    • Pull the panel towards you to remove the panel.
  4. Samsung NP305E5A-A03US Optical Drive Replacement: 手順 4、 1の画像 1
    • Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  5. Samsung NP305E5A-A03US Optical Drive Replacement: 手順 5、 2の画像 1 Samsung NP305E5A-A03US Optical Drive Replacement: 手順 5、 2の画像 2
    • Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
  6. Samsung NP305E5A-A03US Optical Drive Replacement: 手順 6、 1の画像 1
    • Remove the Hard Drive by lifting it towards you.
  7. Samsung NP305E5A-A03US Optical Drive Replacement, Optical Drive: 手順 7、 1の画像 1
    • Unscrew the fourteen 9.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the two 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  8. Samsung NP305E5A-A03US Optical Drive Replacement: 手順 8、 2の画像 1 Samsung NP305E5A-A03US Optical Drive Replacement: 手順 8、 2の画像 2
    • Insert the plastic opening tool between the seam of the back panel and the laptop.
    • Slide the plastic opening tool along the seam to loosen the back panel from the laptop.
    • It may be difficult to slide the plastic opening tool along the seam, so you may have to apply some force.
  9. Samsung NP305E5A-A03US Optical Drive Replacement: 手順 9、 3の画像 1 Samsung NP305E5A-A03US Optical Drive Replacement: 手順 9、 3の画像 2 Samsung NP305E5A-A03US Optical Drive Replacement: 手順 9、 3の画像 3
    • Remove the Back Panel by lifting it towards you.
    • It may take some force to remove the Back Panel.
  10. Samsung NP305E5A-A03US Optical Drive Replacement: 手順 10、 2の画像 1 Samsung NP305E5A-A03US Optical Drive Replacement: 手順 10、 2の画像 2
    • Remove the Optical Drive by sliding it away from the laptop.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Kris Stobbe
メンバー登録日: 10/30/16
585 ポイント
3のガイドは作成済み
チーム
Baylor, Team 5-7, Williams Fall 2016 Baylor, Team 5-7, Williams Fall 2016人のメンバー
BU-WILLIAMS-F16S5G7
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 335
