はじめに
In this guide you will learn how to remove the back cover in order to access and replace a damaged or broken hard drive.
必要な工具と部品
Begin with the laptop lying to its back revealing its underside.
Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
Unscrew the 4mm screw, and slide the cover off away from the computer to reveal the housing for the hard drive and RAM boards.
3 の人々がこのガイドを完成させました。
