メインコンテンツにスキップ
Samsung NP-R540-JA09US Front Panel Replacement
必要な工具と部品
  1. Samsung NP-R540-JA09US Front Panel Replacement, Battery: 手順 1、 1の画像 1
    • Turn off laptop before starting.
    • Remove power cable before starting.
    • Flip the laptop over so that the bottom of the laptop is facing upwards.
  2. Samsung NP-R540-JA09US Front Panel Replacement: 手順 2、 1の画像 1
    • Pull the two latches outward.
  3. Samsung NP-R540-JA09US Front Panel Replacement: 手順 3、 2の画像 1 Samsung NP-R540-JA09US Front Panel Replacement: 手順 3、 2の画像 2
    • Slide the battery out of the laptop.
  4. Samsung NP-R540-JA09US Front Panel Replacement, Optical Drive: 手順 4、 1の画像 1
    • Remove securing screw with the PH0 head.
  5. Samsung NP-R540-JA09US Front Panel Replacement: 手順 5、 1の画像 1
    • Slide the optical drive out and remove it from the device.
  6. Samsung NP-R540-JA09US Front Panel Replacement, Keyboard: 手順 6、 1の画像 1
    • Remove the two Phillips #0 screws labeled KBD.
    • There are 5 clips along the top of the keyboard. Insert a thin opener tool (iSessamo tool or similar) between each clip and the keyboard tray to release it.
    • Make sure to pry the metal keyboard base and not the keycaps.
  7. Samsung NP-R540-JA09US Front Panel Replacement: 手順 8、 1の画像 1
    • Do not bend your keyboard as shown in this picture.
    • Lift the keyboard up to release catches on the sides, then slide the keyboard towards the screen to slide tabs out of the slots at the bottom.
  8. Samsung NP-R540-JA09US Front Panel Replacement: 手順 9、 2の画像 1 Samsung NP-R540-JA09US Front Panel Replacement: 手順 9、 2の画像 2
    • Disconnect the keyboard cable from the motherboard.
  9. Samsung NP-R540-JA09US Front Panel Replacement, Front Panel: 手順 10、 1の画像 1
    • Remove the two screws with a Phillips #00 screwdriver.
  10. Samsung NP-R540-JA09US Front Panel Replacement: 手順 11、 1の画像 1
    • Remove the highlighted screws with a Phillips #0 Screwdriver.
  11. Samsung NP-R540-JA09US Front Panel Replacement: 手順 12、 3の画像 1 Samsung NP-R540-JA09US Front Panel Replacement: 手順 12、 3の画像 2 Samsung NP-R540-JA09US Front Panel Replacement: 手順 12、 3の画像 3
    • Pry the front panel away from the base with an Opening Tool.
  12. Samsung NP-R540-JA09US Front Panel Replacement: 手順 13、 2の画像 1 Samsung NP-R540-JA09US Front Panel Replacement: 手順 13、 2の画像 2
    • Disconnect the speaker wire from the motherboard.
終わりに
作成者
3人の作成者と共同で作成されました。
Daylyn Bourland
メンバー登録日: 09/21/18
285 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team S6-G4, Thompson Fall 2018 University of North Texas, Team S6-G4, Thompson Fall 2018人のメンバー
UNT-THOMPSON-F18S6G4
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 457
