はじめに
If your computer is not turning on or is losing power quickly, this guide provides steps to replace the battery. The optical drive, hard drive, and back cover must be removed first.
必要な工具と部品
Flip the laptop over.
Remove the 6 mm screw with the Phillips #000 screwdriver.
Flip the laptop.
Use the Phillips #000 screwdriver to unscrew the 6 mm screw from the square panel.
3 の人々がこのガイドを完成させました。
