はじめに
In this guide, we will demonstrate how to replace the hard drive of your Samsung NP-N102S-B05PH laptop.
Replacing the hard drive is a quick way to solve any issues resulting from common hard drive issues including; a slow startup, random crashes, corrupted files, and problems with opening files and media. A faulty drive can result from many things, including running at total or near-full capacity.
If the hard drive has been tested and is causing issues, it's a good idea to replace it and possibly upgrade storage capacity.
Before beginning this repair, power off your laptop and unplug your device from the power adapter.
必要な工具と部品
Power down your laptop, and position the laptop with the bottom cover facing upwards.
ある他の人がこのガイドを完成しました。
