はじめに
An unresponsive keyboard is a common problem with computers. When problems arise you will need to either replace the keyboard, or attempt to fix the hardware. Either way, the keyboard must be removed from the device.
必要な工具と部品
Turn off the computer.
Disconnect the charger cable from the computer.
Flip the computer over so the underside is facing up.
終わりに
ある他の人がこのガイドを完成しました。
