メインコンテンツにスキップ
Samsung NP-130-JA01US Fan Replacement
必要な工具と部品
  1. Samsung NP-130-JA01US Fan Replacement, Battery: 手順 1、 1の画像 1
    • Turn off the computer.
    • Disconnect the charger cable from the computer.
    • Failure to disconnect the charger cable from the computer could result in an electric shock.
    • Flip the computer over so the underside is facing up.
  2. Samsung NP-130-JA01US Fan Replacement: 手順 2、 2の画像 1 Samsung NP-130-JA01US Fan Replacement: 手順 2、 2の画像 2
    • Slide the left and right slider buttons fully away from each other.
  3. Samsung NP-130-JA01US Fan Replacement: 手順 3、 1の画像 1
    • Pull the battery out of the computer.
  4. Samsung NP-130-JA01US Fan Replacement, Fan: 手順 4、 2の画像 1 Samsung NP-130-JA01US Fan Replacement, Fan: 手順 4、 2の画像 2
    • Using a Phillips 1 screwdriver, carefully remove all 12 screws of the back cover.
    • The screws are Phillips 1 (PH 1) with a length of 60 millimeters (mm)
    • Do not force the screwdriver as you might damage the screws.
  5. Samsung NP-130-JA01US Fan Replacement: 手順 5、 3の画像 1 Samsung NP-130-JA01US Fan Replacement: 手順 5、 3の画像 2 Samsung NP-130-JA01US Fan Replacement: 手順 5、 3の画像 3
    • With the plastic opening tool, carefully separate the back cover from the computer frame.
    • Starting at one of the corners of the computer, work your way around the edge until you reach the other corner.
    • Do not attempt to pry it open, putting too much force into one location might damage the computer.
    • As you go around the sides of the computer, free the inside latches with the plastic opening tool.
    • Once you have an opening, carefully use your hands to separate the back cover.
  6. Samsung NP-130-JA01US Fan Replacement: 手順 6、 2の画像 1 Samsung NP-130-JA01US Fan Replacement: 手順 6、 2の画像 2
    • Locate the fan (marked in a red square).
  7. Samsung NP-130-JA01US Fan Replacement: 手順 7、 3の画像 1 Samsung NP-130-JA01US Fan Replacement: 手順 7、 3の画像 2 Samsung NP-130-JA01US Fan Replacement: 手順 7、 3の画像 3
    • Using a Phillips 1 screwdriver, remove the screw marked in a red circle.
    • The screw is a Phillips 1 (PH 1) with a length of 40 millimeters (mm)
    • Do not use too much force on the screw driver, you might damage the screw.
    • Using your hands, carefully unplug the cords marked in a green square.
  8. Samsung NP-130-JA01US Fan Replacement: 手順 8、 2の画像 1 Samsung NP-130-JA01US Fan Replacement: 手順 8、 2の画像 2
    • Carefully remove the fan.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Alejandro Guerra Piol
メンバー登録日: 09/12/16
319 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 9-6, Lacy Fall 2016 USF Tampa, Team 9-6, Lacy Fall 2016人のメンバー
USFT-LACY-F16S9G6
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 289
