この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Cooling fans are integral to keep the components inside your laptop from overheating, and a damaged, broken, or insufficient one can means very bad things for your laptop. This guide will show you how to get to it and remove it for inspection or replacement. Most of the steps are fairly simple, but be careful with ribbon connectors and snap-connectors holding down housing plates, breaking those can cause trouble for you down the line.
If your laptop regularly overheats, replacing this component should be something you look into. This guide will also show you how to access and remove your HDD, your DVD drive, and your keyboard if you need access to any of those. Good luck!
必要な工具と部品
Remove the battery by sliding the battery release latches laterally outward into the unlatched position.
Slide the battery upwards out of the battery housing.
Remove the SD card placeholder.
Disconnect the white USB drive plug by pulling outwards using a nylon spudger.
Disconnect the blue DVD player ribbon tab by pulling the blue tab outwards laterally away from the mother board using a nylon spudger.
Disconnect the screen connection wire by pulling it towards the screen using a nylon spudger.
13 の人々がこのガイドを完成させました。
2 件のコメント
Hi where can I get a fan for my R580 Samsung laptop. Please help i have tried to find one but no luck!!! I stay in South Africa. Thanks
Deon Kotze - 返信
