メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung N150 Plus RAM Replacement
必要な工具と部品
  1. Samsung N150 Plus RAM Replacement, Battery: 手順 1、 1の画像 1
    • Turn off the computer.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop upside down with the front face down on a flat surface.
    FixBotに聞いてみる
  2. Samsung N150 Plus RAM Replacement: 手順 2、 2の画像 1 Samsung N150 Plus RAM Replacement: 手順 2、 2の画像 2
    • Slide the left and right switch to the "unlocked" position.
    FixBotに聞いてみる
  3. Samsung N150 Plus RAM Replacement: 手順 3、 2の画像 1 Samsung N150 Plus RAM Replacement: 手順 3、 2の画像 2
    • While holding the left and right hand switches in the "unlocked" position, push the battery away from the computer.
    FixBotに聞いてみる
  4. Samsung N150 Plus RAM Replacement, Back Panel: 手順 4、 1の画像 1
    • Using the Phillip's 00 screwdriver, unscrew the fourteen 7mm screws until the back panel comes loose.
    FixBotに聞いてみる
  5. Samsung N150 Plus RAM Replacement: 手順 5、 1の画像 1
    • Using either the blue plastic opening tools or spudger tool, wedge one in between the back panel and the laptop.
    • Apply pressure upwards till the back panel pops off.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
    FixBotに聞いてみる
  6. Samsung N150 Plus RAM Replacement: 手順 6、 2の画像 1 Samsung N150 Plus RAM Replacement: 手順 6、 2の画像 2
    • The computer should be open with the motherboard exposed and internal components exposed. You should now be able to access the Fan and RAM. There are more necessary steps to follow before accessing the screen and keyboard.
    FixBotに聞いてみる
  7. Samsung N150 Plus RAM Replacement, RAM: 手順 7、 2の画像 1 Samsung N150 Plus RAM Replacement, RAM: 手順 7、 2の画像 2
    • Using your hands, push the two metal clip holders on each side away from the RAM till you hear a clicking sound.
    • If you push the metal rods away from the RAM as directed, the RAM will pop up at an angle.
    FixBotに聞いてみる
  8. Samsung N150 Plus RAM Replacement: 手順 8、 1の画像 1
    • Gently pull out the stick of RAM.
    FixBotに聞いてみる
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
patrick Russell
メンバー登録日: 04/03/16
809 ポイント
6のガイドは作成済み
チーム
1件のガイドコメント
There is no need to open the entire casing. There is a special lid on the back that covers the SODIMM for easy access. It can be replaced removing only one screw.
Fred - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 43
今までの合計 2,204
