メインコンテンツにスキップ
はじめに
Use this guide to replace the motherboard of the Samsung Mythic SGH-a897.
パーツ
パーツは指定されていません。
  1. Slide your fingernail into the slit at the bottom of the phone to remove the back cover.
    • Slide your fingernail into the slit at the bottom of the phone to remove the back cover.
  2. Place your finger in either of the bottom corner of the battery slot and lift to remove the battery.
    • Place your finger in either of the bottom corner of the battery slot and lift to remove the battery.
  3. Remove six 5 mm Phillips #0 screws from the back of the phone.
    • Remove six 5 mm Phillips #0 screws from the back of the phone.
  4. Insert a plastic opening tool into the seam between the back case and the rest of the phone.
    • Insert a plastic opening tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back from the phone.
  5. Use a plastic opening tool to disconnect the camera cable from the motherboard. Carefully remove the camera from the phone.
    • Use a plastic opening tool to disconnect the camera cable from the motherboard.
    • Carefully remove the camera from the phone.
  6. Remove the two remaining 3.8 mm Phillips screws.
    • Remove the two remaining 3.8 mm Phillips screws.
  7. Firmly grip the black lever with tweezers Use the tweezers to flip the black lever up so that it is perpendicular to the motherboard.
    • Firmly grip the black lever with tweezers
    • Use the tweezers to flip the black lever up so that it is perpendicular to the motherboard.
  8. Carefully use the tweezers to slide the black ZIF cable out of the socket.
    • Carefully use the tweezers to slide the black ZIF cable out of the socket.
  9. Use the tweezers to unclip the black connector. Use the tweezers to unclip the black connector.
    • Use the tweezers to unclip the black connector.
  10. Use the tweezers to unclip the orange ribbon cable from the side of the phone. Use the tweezers to unclip the orange ribbon cable from the side of the phone.
    • Use the tweezers to unclip the orange ribbon cable from the side of the phone.
  11. Use the tweezers to unclip the other orange ribbon cable.
    • Use the tweezers to unclip the other orange ribbon cable.
    • Work carefully. This is a very delicate part of the phone that can easily be broken.
  12. Slide one side of the tweezers underneath the red and blue wires of the capacitor. Carefully apply pressure away from the phone to lift.
    • Slide one side of the tweezers underneath the red and blue wires of the capacitor.
    • Carefully apply pressure away from the phone to lift.
  13. Carefully tilt the motherboard up from the back of the phone. Don't remove the motherboard completely. There is one more clip on the backside of the motherboard that needs to be removed.
    • Carefully tilt the motherboard up from the back of the phone.
    • Don't remove the motherboard completely. There is one more clip on the backside of the motherboard that needs to be removed.
    • Use tweezers to unclip the black connector.
終わりに
Morgan Yost
メンバー登録日: 2013年04月08日
46 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 17-1, Regan Spring 2013 Cal Poly, Team 17-1, Regan Spring 2013人のメンバー
CPSU-REGAN-S13S17G1
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 397
